hi folks,,,,,, ive got a new awc708c controller and im having trouble getting it to read work files ...... it recognises upgrade / config files etc so it is reading the drive but as i said it wont read my work files..... ive got them saved in lasercad as PWJ files... am i doing something wrong???? any help would be appreciated ..thanks
I was also searching for solution on this problem. I will put solution that worked for me here, maybe someone will need it. Disk needs to be FAT32 but when formating it - type needs to be Primary (not Logical) and it will work fine . EaseUS Partition Master and other disk managment softwer have that options when formating. Also you save file in *.ud5 format from LaserCAD (when you click Download button on right side then you have option to Save document to UFile)
