hi guys...... its my first time on here and very new to all this and wondering if i could have some help please.....
i bought a chinese cutter a few weeks ago and although it works well i decided to upgrade it using a Awc708c controller.
on the original setup the x &y stepper motors are connected directly to the board ( 4 wires each red/white/blue/yellow).
my question is .... do i need to install stepper drivers to use this new controller... any help would be much appreciated ...thanks
hi chippypah ,,,, thanks for replying ............ the motors are definately straight onto the board .... no drivers in between them .........ive ordered a pair so i can connect to my new controller ..fingers crossed its not too hard to figure out the dip switch settings required lol ..
its one of the lihuiyu studio labs that uses a dongle to verify authenticity ....... it seems to work well but then again its the only cutter ive ever used so cant compare it to anything else.... the reason im upgrading is because the software is set at 75% laser power and non adjustable....although speed is....im having to do each job in 2 stages ...engrave at whatever power then adjust power manually on cutter before cut operation ..and there is no jog option on software either which i could be doing with
Did you ever get a reply about the drivers? I have the 36volt board like yours and can not find servo drivers. I think they are built into this board.
My AW708C hasn't arrived yet. Did you install stepper drivers?
hi steven .... yep i had to install 2x stepper motors ...... awc is well worth the cost ..... any problems installing it just drop me a text (pm me for number) ... i can't answer calls very often as usually working but i will get back to you
