Originally Posted by
Vulcan R&D
I found more info it is an RDLC220-B from Ruida. I did find that I could change the 'steps' on the stepper driver itself so that I can get the X and Y axis to actually draw a square instead of a rectangle when I submit a square to be cut, however there is still something wrong as a 50mm square comes out at 53.975mm when cut. The X axis homes in the correct direction but if you press left on the keypad then it moves right.
If I just knew the password for the vendor settings I think I could fix it...does anyone know the Laserwork vendor settings password? I have PMed the Gweike folks here.
