A few things, Woody. First, in this case, more really is better. In addition to greater capacity and shorter cut times, the ability to run the tube at reduced power will extend its life. There WILL be a performance drop over the life of the tube. You'll also want to consider what lenses come with or may be fitted to the laser nozzle; different tasks and material dimensions will demand different sized lenses.
I highly advise researching everything about the process you plan from one end to the other- from configuring the laser, managing stock, drivers and software, to air filtration and climate control.
