Laser Engraver wont Engrave!
Results 1 to 8 of 8
Thread: Laser Engraver wont Engrave!
    Dec 2016
    Default Laser Engraver wont Engrave!
    Hello, first time posting reaching out for help! I have a Hurricane (chinese) 60 w laser machine. It has been humming along great but now has a problem I can't fix. When I send it an engraving project and hit start, it moves to the bottom extent of the Y axis (vertical) of the project, and then it moves quickly in a straight line up wards to the top extent of the y axis of the project. It doesn't make passes side to side. If you send it different sizes of projects it knows the new extents of the top and bottom, but just wont make passes to engrave.
    I don't know if I am explaining this well enough, I hope I am.
    The funny thing is that if I load an old saved project, it engraves it fine. The only problem is if I send it something new. Cutting works fine.
    Any Ideas?
    Default Re: Laser Engraver wont Engrave!
    you can try to connect it to computer with usb cable (if your system is RD ),then use the computer to start working. hope can help you . my advise you can upload a picture of the control panel,so we can check the system.
    Web:Jinan Blue Elephant CNC Machinery Co.,Ltd.
    Whatsapp/mobile:0086-15064026772
    Email: manager@elephant-cnc.com
    Jan 2017
    I believe I am experiencing the exact same. Might you have found a solution? I made the following video of the issue in action
    Thanks,
    -R
    Quote Originally Posted by LazerDave View Post
    Any Ideas?
    Nov 2005
    Argentina
    Any Ideas?
    Have you resolved the problem? i am having the same and EXACT problem!
    awaits for the answer!
    regards
    rick
    Nov 2005
    Argentina
    Well i will reply myself for someone future´s reference.
    In: system settings -> Advanced Functions uncheck the enable from rotate engrave! thats all!
    regards
    rick
    Nov 2012
    I was thinking writers block!
  7. #7
    Nov 2005
    Argentina
    Quote Originally Posted by tom o View Post
    really i dont understand what do you are saying, could you explain please
    regards
    rck
  8. #8
    Member germanr's Avatar
    Aug 2018
    Buenos Aires
    Thank you Flor for your tip!
    Soy tecnico de laser con experiencia.<br />Usuario de maquina de corte laser Buchicnc EVO 14.<br />Usuario de grabadora laser por fibra EVO 5.<br />Usuario de router CNC, con mesa de 3 x 2 mts Auto Tool Changer<br />Diseño mis propios archivos maquinas de corte laser con CorelDraw, LaserCut 5.3, RDWorks V8.<br /><a href="https://buchicnc.com" target="_blank">Estas son mis maquinas de corte láser BuchiCNC</a><br /><a href="https://buchicnc.com/producto/maquina-de-corte-laser-evo-14/" target="_blank">EVO 14</a><br /><a href="https://buchicnc.com/producto/maquina-de-corte-laser-evo-5/" target="_blank">EVO 5</a><br /><br /><a href="https://buchicnc.com/en/" target="_blank">Laser cutters &amp; CNC Routers BuchiCNC USA</a><br /><a href="https://buchicnc.com/en/product/cnc-router-mr-atc-6-standard-line/" target="_blank">CNC Router ATC</a><br /><a href="https://buchicnc.com/en/product/laser-cutting-machine-evo-14/" target="_blank">EVO 14</a>
