about to buy a chinese laser co2 machine - advice required - Page 3
Page 3 of 3 FirstFirst 123
Results 25 to 27 of 27
Thread: about to buy a chinese laser co2 machine - advice required
  1. #25
    Feb 2016
    United Kingdom
    Default Re: about to buy a chinese laser co2 machine - advice required
    I am not in Birmingham and have nothing to do with them. I am by Birmingham and that is the reason I went to look at these machines. I thought I was doing someone a favour because I had found a decent machine with some good customer service.
    Sorry for trying to help
  2. #26
    Nov 2016
    United Kingdom
    Quote Originally Posted by mark747 View Post
    why so touchy? i just said good find. and also pointed out that i wouldnt buy that as it doesnt support multi colour cuts, had you read the thread you would of noticed ive already bought one
  3. #27
    Jun 2012
    Brunei Darussalam
    Just as an FYI for others looking looking at a cheap Chinese laser, replacing the Chinese supplied controller with a decent, standard-based one is very simple. So, if your favoured laser doesn't support different colours, get a controller that does.
    An Arduino/RAMPS combo running decent firmware, a TinyG or Smoothie board will run you from $20-100 and completely transforms your toolpath.
    I have all three and they all offer much more than your average Chinese controller. I have a TinyG running over Bluetooth, a Smoothie connected by Ethernet and controlled via the web, and replacing the existing controller is a breeze.
    Using stepper-motor equipped laser mechanisms, higher resolution is always better and the ability to get 1/128 or 1/256 steps with advanced motion, jerk, acceleration, etc. should justify the upgrade alone.
    As a mixed Mac/PC/Linux user, the ability to use open-source, rather than pirated software that only runs on windows is a massive improvement. For my current CNC and 3DP machines I use a raspberry Pi to front end the device, effectively giving each machine its own dedicated computer.
    I viewed my first laser as a box of donor hardware to which I would add the electronics I wanted. Budget £100/$150 and you can transform that clunky old controller into something swish and modern.
