Laser cutting engraving samples,Made by Triumphlaser
Page 1 of 2 12 LastLast
Results 1 to 12 of 24
Thread: Laser cutting engraving samples,Made by Triumphlaser
    Sep 2016
    China
    Post Laser cutting engraving samples,Made by Triumphlaser
    3D acrylic spider laser cutting
    Material:3mm yellow acrylic,3mm green acrylic
    Machine:Co2 laser cutting machine TR-1390
    Laser Power:80W
    Speed:15mm/s
    Power:45%
    Project time:45 minutes
    Free vector file will be sent you If you have interest.
    A professional laser cutting engraving marking machine manufacturer!
    Sep 2016
    China
    Default Re: Laser cutting engraving samples,Made by Triumphlaser
    Ant acrylic laser cutting
    Laser cutting engraving samples,Made by Triumphlaser-acrylic-laser-cut-ants-1mm-jpg
    Sep 2016
    China
    Photograph laser engraving on wood.It is easy to do.
    Laser cutting engraving samples,Made by Triumphlaser-aa-1-jpg
    Sep 2016
    China
    This laser marking machine advantage is high efficiency, low maintenance, easy operate, environmental protection. Machines have export to South Asia, Middle East, Europe and America, Africa and more than 60 countries.
    The main advantage as following:
    1. High efficiency:
    Triumphlaser has benefited from the advantages of technological innovation, and continuously improve the efficiency of the laser marking system.
    2. Low maintenance:
    Using high quality components in laser industry, simple using& maintenance, 24hours no fault operation.
    3. Easy operation:
    Our laser Equipments can working automatically with the control of computer.After a simple training, everyone can operation it freely.
    4. Environmental protection:
    Laser marking is processed in non mechanical "knife", does not have the corrosion to the work surface, no "tool" wear, no poison, no pollution.
    5. Complete technology supporting
    Sep 2016
    China
    MDF laser cutting 3D Kylin
    Laser cutting engraving samples,Made by Triumphlaser-1-jpg
    Sep 2016
    China
    Our customer's work ,It looks so cool!
    Laser cutting engraving samples,Made by Triumphlaser-triumphlaser-customer-jpg
  7. #7
    Sep 2016
    China
    DIY acrylic wall clock,Play your imagination and make it a reality
    Laser cutting engraving samples,Made by Triumphlaser-jpg
  8. #8
    Sep 2016
    China
    I just made a model plane with plywood,I'd be happy to share it with you.
    Laser machine: triumphlaser TR-1390
    Material: 5mm plywood
    Speed:20mm/s
    laser Power:80W
    Laser cutting engraving samples,Made by Triumphlaser-wood-plane-model-laser-cutting-machine-jpg
  9. #9
    Sep 2016
    China
    Customized phone case with Fiber laser marking machine
    Laser cutting engraving samples,Made by Triumphlaser-phone-case-laser-marking-machine-jpg
  10. #10
    Sep 2016
    China
    DIY wood phone case-laser engraving
    Laser cutting engraving samples,Made by Triumphlaser-iphone-6-plus-wood-case-grain-laser
  11. #11
    Sep 2016
    China
    Fiber laser cutting machine is widely used in industrial production, because the price of a substantial reduction, it has a high cutting speed, and the cutting edge is very beautiful.
    Laser cutting engraving samples,Made by Triumphlaser-img_5025-jpg
  12. #12
    Sep 2016
    China
    UV laser marking machine for plastic&glass
    Laser cutting engraving samples,Made by Triumphlaser-triumphlaser-uv-laser-marking-machine-plastic-jpg
    UV laser widely used in 3C industry marking, as well as industrial micro machining, including marking for a diversity of materials, LED scribing, laser rapid prototyping, removal of metal and non-metal coating, silicon wafer processing and so on.
