Need Help! AWC608 working with Windows 10?
Results 1 to 5 of 5
Thread: AWC608 working with Windows 10?
    Feb 2013
    New Zealand
    Default AWC608 working with Windows 10?
    Hi all
    I've got a laser-cutter working with an AWC608... it's currently running with an old XP machine running lasercad - but I'd like to swap that machine out for a windows 10 one.
    Does anyone know if this is possible?
    At the moment, it all looks good until I try to download the file (using USB) - whereupon it triumphantly says
    "Communicating Unsuccessful!"
    And that's as far as it gets.
    Any help, greatly appreciated
    Nick
    (details)
    AWC608
    Main Board : 7.14.08.22
    LCD Board : 5.13.09.15
    Lasercad v6.71
    Default Re: AWC608 working with Windows 10?
    Hi Nick
    You could change the compatibility of your software in win 10 , right click your mouse , property , compatibility , and chose XP compatibility .
    Ph main board can use dirrectly on Win10 , and support the newest coreldraw , like X8 .
    About the Communicating , you could insert the USB cable to the USB interface of mainboard dirrectly .
    Hope helpful .
    Triumph David
    May 2015
    Download the updated version of LASERCAD here ..... Works seamlessly on Windows 10 .....
    http://www.sztrocen.com/download/sof...asercad-v7-68b
    Enviado de meu ASUS_Z00AD usando Tapatalk
    Feb 2013
    New Zealand
    Somewhere between those two solutions, and a couple of stops and starts, everything now appears to be working perfectly.
    Thanks for your help everyone. Most appreciated.
    Nick
    Sep 2011
    finland
    Hi!
    Yes works but you haw to install unsigned usb driver first.
