I'm thinking of buying one of those cheap lasers ( around 40W). I am wondering if it would be be possible to vary the power while cutting by using the z axis output of linux cnc, by,for example connecting a small stepper to a variable resistor?Similar Threads:Need Help!- Constant Power W/ Variable Wire Length diy variable voltage stepper power supply Variable regulated DC power supply for testing? 0 - 90+ volt variable DC power supply
Just change the control board to a ramps board. It can take g-code and vary the laser output. Lots of info on Google. Sent from my A3-A20FHD using Tapatalk
Thanks, I'll do a search
View Tag Cloud
Forum Rules
