I'm seriously considering buying a new Boss 2436 laser for engraving. I currently own cnc equipment and use a 4th axis setup on my mill. My question is can I use the same 4th axis on this new engraver?? I can make an adapter to plug in to whatever type of connection is required. I'm a little confused on the software side of an engraver. How do I tell the laser how many steps equal a degree with boss's Engrave Lab software?? Are CNC mills and laser engraver's two different animals? I'm not against purchasing the rotary attachment the Boss sells but hey, if i can save $800 i'm willing to make an adapter or two. The main reason i'd like to use my extisting 4th axis is because its already set up with a 5c collet jig and tail stock to hold gun barrels for engraving. Any thoughts??
