try larger circles and different speeds as well, if you have any other issues or your adjustments are for smaller circles, it may cause headache in large ones... fixing at large scale is the key as you go bigger and getting to a smaller error margin, it becomes more precise... if you know what i mean, 0.2 mm error in an 8mm circle will be greatly amplified in a 250mm circle! be careful with those values...
also for smaller circles there are some adjustments for backlash issues in config (s) / system settings / general settings /small circle limit... each option (small circle sizes up to 8 mm? is defined but you can fine tune them to your machine) has different speed value...
