- Need Help!- chinese laser X Y problem
hello there !
We have a lasercut from china 50W 50x30cm 644XG.
And i have a little problem :
When i draw a square of 100mmx100mm the square is around 100.5mmx101.5mm
if i draw a 200mmx200m I got 201mmx203mm
So i think i ve to set the pulse for the stepper... because X is doing +0.5% and worse Y is doing +1.5%
but i dont know where to do it.
We use RDWORK V8.01
Any help will be ace !
Re: chinese laser X Y problem
go into vender settings under file the Password should be RD8888
Have a look at this post
http://www.cnczone.com/forums/genera...ml#post1648484
Remember to read the configuration from the machine before making changes and saving them back.
Thanks a lot ! it works !
- You may not post replies
- You may not edit your posts
Forum Rules
