Take your nose cone off and try that last shot again.
Gozzie
Loss power laser cutting, laser beam output tube anomaly,
you have solutions to this problem?
Gozzie
So is this a new issue since I see the last one of double lines is solved as of today?
Anyhow - that output looks odd from the tube to mirror #1. It should be a tighter beam in my opinion. That said, the lens should be condensing that beam more at the end I think. Anyhow, you might send that picture to the manufacturer of the tube (if under any sort of warranty still) and see what they say. I would also try with the nose cone off to make sure it isn't hitting the cone after the lens.
In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
power loss, anomaly tube laser 50 watt
Might be too little power. They can act a little strange if just barely getting enough power to make a solid beam... Try a bit more power (if you are at a lower level now) and try again.
Setting laser power 70, this tube is new, few working hours,
possible problem with power supply laser ?
Beams are normally about 3mm. It appears your output is a circle. I got the same thing on a 40w tube after I pushed it with poor cooling, poor flow or both. It didn't cut well after that so I replaced the tube. I also completely updated the cooling system and don't cut over ~20 deg c and about 80% rated power. So far no issues.
Problem associated with the loss of power of the laser beam?
Distilled water in the cooling system? I had a similar issue with a 40w laser tube till i rinsed the tube, lines, and pump out with distilled and refilled the tank with distilled water. I think the laser was arcing through the water to get out through the pump wiring.
Distilled water is a poor conductor vs tap water which is a great conductor.
