Hello,
What is the price of a laser system (fiber or CO2) capable of cutting up to 5mm steel.
Just the laser cutter and its power system, not the motion control system or anything else.
I just want to see if it is possible to build my own CNC laser cutting machine.
Thanks.
Last edited by SevenQQ; 11-13-2015 at 03:37 AM. Reason: Professional fiber and yag laser cutting machine manufacturer
HI Drakke,
for cutting 5mm steel then co2 laser cutting not ok, fiber cutting is ok.
fiber Racuys 500w laser is ok
like our model LF1325 500w Rauys laser can cut very good.machine use cypcut control system ,Au3-tech cutting head. Taiwan rails guides ,and Japan servo motor, etc
ok, hope can help you .
Quiven form gweike laser
chloe@wklaser.com
skype:wkquiven
I am in the process of building a laser machine based on a Raycus 30W fiber laser.
Yes its only 30W but it is sufficient to do what i need done.
Price wise... 30W unit can be had for under USD5000.-- I paid USD4800.-- but other brands are somewhat less costly.
100W unit typically USD10000.--
CO2 laser will not cut stainless without a special surface treatment paint.
Problem is deciphering user integration information, I am going through that now.
Anybody with interface experience..please chirp .
