Originally Posted by
robertk925
Driven2112:
There are a few different issues to check, some hardware and some software.
I assume that when you say the laser won't run the job that the laser doesn't fire and the laser head doesn't move either; the machine just beeps. I had this same problem on my 50W eBay laser and it was due to the cutting area going beyond the limits of the machine. In other words, the part I was trying to cut was too large relative to the origin (cut starting point). I would send the file from the computer (using the Laserworks software in my case) and the laser machine would beep but nothing would happen. Looking closely at the control panel on the machine showed an error (something like "Frame too large" I believe). The machine thought the origin was somewhere in the middle of the table while I was assuming it was at 0,0. Once I reset the origin closer to 0,0 (using the Origin button on the machine control panel) the part cut fine.
The complicating factor is that the software also has options for where to set the origin as well. You can tell Laserworks (the program that came with my machine) to start cutting at the current head position, at machine zero (0,0 hard wired by the home switches on your machine), or at some other absolute position on the machine. So you need to make sure this is set properly before sending the file to the machine.
If all of this is set correctly (i.e. you have the origin on your machine and in the software set properly so that the part will fit on the bed) the other possibility is that your home switches were reset to the wrong location somehow. There should be a diagnostics mode on your machine where you can tell it to reset the X and Y axes. Typically machines do this when they are first powered on, but sometimes they get out of whack and the machine thinks its origin is not where it is supposed to be.
If the laser head moves but the laser just doesn't fire, then it is probably a laser tube or laser power supply issue (or possibly a water flow sensor error).
-robertk925
