Originally Posted by
robertk925
eaglestone:
I assume you are using a 60W CO2 laser? A CO2 laser can't etch bare brass (or brass-plated steel) unless you use a coating like Cermark/Thermark.
Does "clear lacquer coated with ultra thin color" mean it is painted a color and then clear coated over the paint? If so, you can etch away the clear coat and the paint with a CO2 laser. This should require very little power. If you mean it is brass-plated steel with just a clear lacquer coat, then you can etch away the lacquer, but I don't think you will be able to see much contrast between the etched and non-etched surfaces.
-robertk925
