Problem Importing DXF files with LaserCut 5.3 - ISSUES
Results 1 to 6 of 6
Thread: Importing DXF files with LaserCut 5.3 - ISSUES
    Dec 2013
    Paraguay
    Default Importing DXF files with LaserCut 5.3 - ISSUES
    Hello people
    I have been working with a laser cutter for more than a year now. The machine works
    with LaserCut 5.3 software.
    I use LaserCut just to import DXF files. And here is the thing:
    DXF files imported from InkScape run slow.
    DXF files from Corel work faster using the same settings in LaserCut.
    Any idea why??
    Also DXF files from InkScape are imported "broken appart". So I use the "unite lines"
    tool to bring them together again. DXF from Corel are imported "already united".
    Already tried all exporting options from both programs I can get to imagine but can´t
    get it.
    Any ideas will help
    THANKS!
    Salvatore
    Default Re: Importing DXF files with LaserCut 5.3 - ISSUES
    May be the nature of the lines being transferred. Are they point to point or strings?
    Sent from my iPad using Tapatalk
    Dec 2013
    Paraguay
    That makes sense. Should check further on that.
    Is there a command in Lasercut to switch the nature of the lines?
    Dec 2013
    Paraguay
    A new experience about this problem:
    So I prepared a drawing using InkScape and saved it as a DXF file. Later I imported the file to LaserCut and it took 02:40 minutes to cut the job.
    Then I exported the same file in InkScape as a PDF file. I opened it in CorelDraw and exported as a DXF file again.
    Imported to LaserCut using exactly the same settings and it took 01:37 minutes to cut the job.
    Why does this happen? Any idea?
    Jan 2008
    are both files exporting as the same version dxf you may have to use a legacy version. I had to do this with a different program that could not read auto cad 2012 dxf's but could a 2010 version.
    Dec 2013
    Paraguay
    Hello! Yes, I think you are right. When using Corel Draw there are several DXF versions you can choose but InkScape does not have any.
    It is a shame because Inkscape is open source and free. But in this business time is money so I am going to look for some other software options.
    Thank you all!
