Parameter password reset
Results 1 to 17 of 17
Thread: Parameter password reset
    Apr 2015
    Default Parameter password reset
    Does anyone know what the password would be on the chinese engravers to reset the parameters to the default settings?
    Apr 2015
    Quote Originally Posted by Nolan Yang View Post
    Hello, which controller do you use? different controller has different password. our machine use RDC6442G controller.
    How to use laser software - Thunderlaser
    Hello Nolan. That is the same controller that we use as well.
    Apr 2015
    the password is rd8888, please have a try.
    We tried that password and it did not work.
    Mar 2013
    Default Re: Parameter password reset
    Hello Stephanie, have you solved this problems? sorry for the late reply, I just come back from holidays. please try HF8888.
    Hello Nolan, HF8888 does work for factory default, thank you (I am also using the RDC6442G)! Unfortunately it messed up my y-axis. I was having problem with my PWM set incorrectly for laser control, is there a separate password for factory parameters to fix both my Y-axis issue now and the PWM? (HF8888 and RD8888 do not work for fact para)
    Mar 2013
    Hi Nolan, that password worked thank you!
    Mar 2013
    Nolan, one last question, I have greatly appreciated you help. Is there a vendor default for baseline redsail style machines using the RDC6442G controller? As seen in the thread:
    http://www.cnczone.com/forums/genera...-software.html
    With the images of:
    Parameter password reset-y-axis-1-jpgParameter password reset-x-axis-jpgParameter password reset-laser-jpg
    Is there information available for the Manufacturer Settings, ie the file, or just the numbers?
    Thank you so much!
    Doug
  7. #7
    May 2015
    Russia
    Hello Nolan, I was having problem with RDC6442G controller. When the controller is started, the LED 13 on the controller lights up, and on the display there is an image "Connecting to controller...".
    Further the controller isn't loaded. How it is possible to solve this problem?
  8. #8
    May 2015
    Russia
    Nolan, thanks for the response.
  9. #9
    Mar 2017
    Hi Guys,
    Have you found a fix for this? I also made a mistake of doing both Set Fact Para and Def Fact Para reset since I was trying to fix the skipping issue but it messed up the axis and is now creating weird noises that were not present before. How do I set this up? And is there any firmware updates to fix the skipping issue?
    Hoping for your reply.
    Thanks,
  10. #10
    Apr 2017
    I have the same problem, I had to perform the two resets to fix a over run issue I had when doing a scan. Now when I turn on the machine it wants to about 1m out side the machine on the top left, and I can't workout how to set it's home default for start up.
  11. #11
    Aug 2015
    Quote Originally Posted by MrMusk View Post
    New to the forum Hi
    I’m having the same problem with red/black Chinese 7050
    Can anyone point me I’m the right direction ? Thanks ????
  12. #12
    Apr 2017
    Hi Stu44,
    The way I fixed it was, I had to play with the setting for the X & Y axis, depending of which way it is out. I had to flip them or change them positive to negative or visa-versa. See Cogolith’s post below, for the screens. To get these in RD Works go to vendor setting, password is rd8888.
  13. #13
    Member Jim04's Avatar
    Jul 2020
    I bought a Chinese laser cutter model SH-G350 from Amazon and came with no password or information to contact anyone. Can someone please help me?
    Also says RDC-V8 0063
  14. #14
    Jan 2008
    Try rd8888 as your password
  15. #15
    Member Cncmaistros's Avatar
    Apr 2021
    help friends I have a co2 80w red black 700x500 I pressed HF8888 Default para and all the settings are broken what do I do to adjust it RD8888 does not work on the machine what code do I put in the factory parameters? mrphotogreece@gmail.com
  16. #16
    Nov 2016
    hello sir, I have same issue, I understand we need the vender settings or the vender file were you able to get it? if so could I have the file as I have the same machine as you. thanks
  17. #17
    Member Stacy0612's Avatar
    Aug 2022
    Quote Originally Posted by getechy View Post
    I too am having the same issues. Any luck with what the steps are to fixing it. Thanks!
