Not at all stupid to not know if there was a fuse or where it is located. It is ignorance which is always where we have to start. I was "ignorant" on both of those things before Retro's post. If I would have had a blown fuse in my unit I would have found it (blown fuse) in 5 minutes or so with a continuity check (ohm meter). I would have been ignorant about if there was a fuse, ignorant of where there was a fuse, but "informed" about how to figure all this extremely basic circuit tracing out. I don't believe you followed the directions in my first post above (#3) or you would have found that your rear panel mains connector was open on one leg two days ago. We overcome ignorance with knowledge.
It would be nice to know if rear connector was injured when the short circuit blew the fuse? Continuing with my first post (#3) above, now we know for sure you had a short circuit (not an open circuit). DO NOT CONNECT THE UNIT TO THE MAINS DURING THESE TESTS. Replace the fuse and replace the (DISCONNECTED FROM MAINS ) power cord into the rear mains connector on the laser. With the switch "off" you should see continuity (1 or 2 ohms) between one of the power cord prongs and one of the input wires on the power switch (just connect one meter lead to one prong and poke all 4 switch connections one at a time and only one of them only should have continuity. Do the same for the other power cord "prong" and it will have continuity to the one of the other switch connectors. There should be no other continuity's any other way you test like across the prongs, The "other"switch connections, either prong to ground, any other place you test on the machine. I expect this first test to be good as explained since your original problem happened after you turned on the switch. With the successful conclusion of these tests we will know your power cord and rear connector and fuse and the input side of the power switch are all working as they should. Get this done and next we will test the switch, wiring between and power supply. Were almost finished with a conclusion we can have confidence in, your supplier can supply the right replacement parts for (probably just a power supply) and you will have enough information to convince him you know enough what your doing to get him to send one), and you can start stinking your house up with laser smoke!
Troubleshooting is a progressive and methodical series of tests that build to logical conclusions.
