Originally Posted by
Retroplayer
Well, if your wiring checks out, fuse is blown, then all that is left is a faulty power supply. If the tube had blown, it probably wouldn't have blown your circuit breaker and it would be very visible. Same for the 24V components.
If it had been the high voltage circuit, you would see arc burns for sure.
Your circuit breaker popping indicates to me, some type of short on the AC side of things which means most of your components should be ok.
As I mentioned, I would look for loose screws and nuts that may have found their way into the power supply. I wouldn't be surprised if you find something and your power supply is probably fine as well.
Regardless of what the seller does to remedy the situation (and I'm sure a remedy will only be sending you replacement parts to install yourself with shoddy instructions on how to do it) you are going to be getting your hands dirty here to get this going again. Perosnally, I would start with some continuity checks starting at the ac input and following it to the supply. On your supply you should have a connector on the left labeled L- FG AC AC. The two ACs are the live and neutral from your inlet. L- and FG are earth grounds which will connect to that yellow wire on your inlet and also to the chassis banana jack.
Do a continuity check between AC and AC pins, then each AC input and the L- and FG pins.
