sry.. i try but didnt firmware upgrade
HI, If you have problems with your 6515 firmware, then you can use these two files. Also they can be used for downgrading from other version.
Step 1:Copy the updated firmware data to the root directory of
USB flash disk (Recommendation: do not save other files to the flash
disk);
Step 2: Turn of the machine
Step 3: Plug USB flash disk into MPC6515
Step 4: Turn on the machine
Step 5: After about 1 minutes, remove the USB flash disk, DSP firmware program will be started.
melody@vip.163.com li@wklaser.com
skype:melody.gweike
thanks for your cooperation
BUT PLS WOULD YOU MIND TO EXPLAIN ME THE OPERATION
After spending 8 months trying to get a Leetro 6515 to work after it decided that it no longer recognizes its "Soft Dog" (and getting no useful help from Leetro themselves) I decided to chuck the stupid thing. I replaced both my controllers with Sinjoe AWC780Plus controllers. I will never touch a Leetro controller again as long as I live. Their support sucks and they simply washed their hands of the problem. Whenever a customer tells me that he is having a problem with a Leetro controller I tell him to replace it with a Sinjoe controller.
Tnx
I will try it,
I hope its working
best regard
tanks you.
have also the dll for thid version?
