pls use gasoline to clean it
GOod morning,
I've 80W Co2 laser machine, my question it's easy.
I've the combo steel work plan and in my cut working makes the sparks that leave the points in the cut line on the material, this is no very clean.
Have you some suggestion about the work plan or some other material that I can put on the work plan?
tina from g.weike laser
EMAIL: tina@wklaser.com SKYPE: lysunshine521
Gasoline? Thank for the suggestion, I'll try it.
But the spark depends when my laser spot hit the steel line on the work plane,
why to clean by gasoline solution?
yes, it's this!
have you the solution?
do not put the material on the steel work table directly,
try to put your material on stilts,
(leave enough space between the table and your material bottom)
good luck.
www.thunderlaser.com
yes I know this solution, good for big and easy cutting,
but when I cut more and little pieces or thinnest material isn't easy,
because or fall down or bend some parts before the cutting it's over.
any way thank you.
I use egg rate light diffusers to keep this from happening
maybe you can try to build/buy a table like below?
https://www.epiloglaser.com/products...ser-series.htm
or
X252_Standard_Products GCC Laser Engraving System
Please fixtureman1 , could you explain me what is the egg rate light diffusers, have you some picture or link please?
ok, maybe I've understand what is, but which material do you use ?
yes maybe it's good, but I can't find the link where I can buy this?
Sorry it is egg crate diffuser should have proof read this better. It is plastic and will not reflect the beam
