Hi! i'm back, sorry for the long time…
now i start to better understand how to work with this machine but i'm not soo satisfied, i work with paper and the cutting velocity and precision are not good. Until 30 mm/s work is acceptable, if i must cut little word or object must decrease until 20-22 mm/s. With straight line can go to 38-40 mm/s. Someone has been successful to cut with precision at fast speed? Need to change all the machine?
Second problem, when cut paper become dirty (honeycomb reflect on the back) especially with white and light colors, i cut at 20% at 20-25 mm/s (paper 200-300 g/m2), i use wrong setting?
