Hello Prompt please relating to resolution engraving. At each machine it is indicated differently, who is for example 0.025 mm in others it 1.5 to 1.5 mm character. What does that mean? What a machine with which resolution provides high-quality engraving. What resolution should have a machine with a working range of +-50x30 (60x40)? Want to learn more about the resolution. Resolution depends on the size of the focal spot, the smaller the emitter so spot is smaller and therefore more resolution, but, because you can reduce the hardware power of the laser (or am I wrong?). Did I understand correctly? If correct what were the values resolution machines have normal resolution? Which machines (manufacturers, models) (what dpi) can engrave wood with the same quality?
Can you please advise what either engraving machine which is similar to the samples provided by me?
P.S
Please tell me what kind of machine in the photo?
