First check if you laser beam goes straight through the middle of the output hole.
If it is OK check your beam profile. Must be round all the way,
If he beam is not round this may cause such a feeling but really it is leaning V shape.
Check cutting profile when cutting perpendicularly to the material edge. Plexi is best for.
Also check it with different power and FL distance to see how the beam behaves.
