Hello,
I am new to this forum and everything CNC. I recently purchased my first CNC machine and its a Trumpf 2503 2600w laser. Anyways, the tech-tables that came with the machine are about useless. They had the machine cutting at half power so modification was done to the tables to make it work accordingly. Data collection manuals are somewhat helpful but I cannot acheive the desired results. Does anyone have any good 2503 2600w tech tables out there? Or better yet is there anyone in the Northwest Ohio area that has run a machine like this or similar. Any help I can get I would appreciate it. I am very new to all of this.
If you are using the tops software or your programmer is using it. you can adjust the tech tables as well as export them directly to the machine. What thickness is the stainless steel that you are cutting
