Chinese laser y-axis problem after rotary use
Results 1 to 17 of 17
Thread: Chinese laser y-axis problem after rotary use
    May 2012
    Singapore
    Default Chinese laser y-axis problem after rotary use
    Need some help here, i have a chinese laser, using lasercut 5.3, MPC6515, after switching the y-axis to use with the rotary attachment, and switching back after, the y-axis just vibrates like mad when i move it, it seems to have something to do with the laser controller i am not sure.
    Try all means to reset it but not working, download config but it is still the same, not the first time this is happening, the last time it happened, it stayed that way for a week before magically becoming normal again.
    Anyone have any ideas ? Or have the some problems?
    Appreciate all help here, thanks!
    Oct 2009
    Belgium
    Maybe there is a bad connection from the y-axis connector. Have you double checked the connection?
    May 2012
    Singapore
    Very sure it's not connection or anything related to the hardware, most probably software, is there any way to reset the laser without using the com? As when i download config, nothing seems to change.
    Hurricane21
    Guest
    First - I hope you removed the plug while the machine was powered down and plugged the Y-axis back in. If not, please power down the machine and do this. Turn Your Machine back on. Next, Reset the Machine Options back to the normal Y-Axis operation (the need and pulse units). Save the Machine Options using the default password. Next - go to download and hit download config. Your machine should beep. You should be back to normal operation.
    May 2012
    Singapore
    Thanks for the reply. Yes, i always made it a point to shut down and switching of the power switch before removing or attaching the rotary, and i did insert the correct settings and download config , including hearing the beep sound countless times. But it doesn't seem to change anything.
    wklaserliu
    Guest
    Default laser cutting machine
    Quote Originally Posted by stekke_stim View Post
    Have nice day !
    I am Quiven Liu from Jinan G. Weike Science & Technology Co.,Ltd. , It is a modern enterprise in combination of researching,producing and selling on Optics,Mechanics and Electronics since year 2004 ..
    It is mainly in producing: laser engraving /cutting machines , cnc routers ,YAG laser engraving machine ,laser marking machines and cutting plotters ,and dear for more information please check our new web and if any products are to your interest please contact me without hesitation .
    Warmest regards !
    Quiven Liu
    Mobile: +86-15698041856
    Email: chloe@wklaser.com
    Skype:wkquiven
  7. #7
    Company Representative Melody-gweike's Avatar
    Sep 2011
    China
    Hi, Jamestan,
    Have you modified the moving distance parameter of y axis back when you finish using the rotary?
    If yes, then the y axis connection cable line from the controller probably be loose or have some problems.
  8. #8
    Registered EXLASer's Avatar
    Nov 2009
    China
    Hi ,
    After using the rotary , the range of Y axis and the move number of Y axis need to change back and download through CFG to the machine successfully . On the Y axis pulse unit , move number and Need pulse you will see . The calculate method of Move : input a estimated value X in Move ; draw a line in the software ,length is Y ; the actual length of the line is Z .
    The accurate value of Move is ?
    X/Y=?/Z
    ?=X*Z/Y
    If this value is not accurate , please calculate repeatedly .
    there also a easy method for you in the future if you want to use the rotary again . THAT IS : before you start to use it , copy the cfg out and save in a positon . After using the rotary ,copy this cfg back to the root directory of laser cut and download cfg .
    XYZ Machinery
  9. #9
    Hurricane21
    Guest
    I had my engineer review your post and he suggested that your drivers may have gotten corrupted and to reinstall them from your disk. Then redownload. If you do not have the disk anymore, PM us and we can send you a download. Maybe this will fix the problem.
    Hurricane Lasers
  10. #10
    Oct 2012
    mexico
    Default Please Help
    hello, i need some help, i don't know how use the rotary wit laser cut 5.3, how i calculate the distance on Y axis to have the right torque? because if i want to engrave 1inch in Y axis, the actually config cut me 7 inch.
    i hope you can help me.
  11. #11
    May 2006
    Quote Originally Posted by carlosneuron View Post
    You need to know how many steps to complete one full rotation of the chuck or drive wheel.
    Depending on whether it is a chuck style rotary or friction wheel style rotary. Then the calculation is;
    For a chuck rotary, Diameter of the work piece in mm, times pi, divided by the steps per rev.
    D*pi/steps per rev.
    For a friction roller style rotary, Diameter of the friction drive wheel in mm, times pi, divided by steps per rev.
    The answer is the distance per step in mm that goes in the Y axis field.
    Greolt
    Attached Thumbnails Attached Thumbnails Chinese laser y-axis problem after rotary use-lasercut-5-1-rotary-step-setting-jpg
  12. #12
    Oct 2012
    mexico
    thank you for the help!
  13. #13
    Dec 2009
    Default Re: Chinese laser y-axis problem after rotary use
    New at laser engraving. I have the same problem after disconnecting the rotary attachment. My y axis dimensions are half the size. Sorry but I don't know what the CFG is and where to find it to download. Is there some kind of reset on the power supply? I've checked my leads and they seam to be okay. I'll check them again. If possible can you email me any help you can give @ - tunastap1@msn.com.
    Thank you for your time,
    Dbtuna
  14. #14
    Dec 2009
    Did you ever get your problem solved?
  15. #15
    Dec 2009
    YES! I figured it out myself. After attempting using the rotary attachment I disconnected it and reconnected the Y-axis plug. I didn't remember to UNCHECK the rotary box in the driver. All is well now.
    Even got the rotary attachment working I got on Amazon.
  16. #16
    Feb 2018
    Huge issue on our end of the co2 laser engraver- no matter what we do to reset the parameters it goes right back to the same, jamming and squealing, anyone that can help us out on how to figure this out? only been a couple weeks and getting no where.
    our office is 810-359-7055, anyway we can get a number to call.
  17. #17
    Feb 2018
    Quote Originally Posted by dbtuna1 View Post
    They sent us perimeters to send to machine and we can't seem to get the machine to read it as a file nor our laser program, any suggestions on how to do it?
    the file is an "rdvset" extension.
    any help appreciated, our office number is 810-359-7055
