Chinese laser y-axis problem after rotary use - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 15 of 15
Thread: Chinese laser y-axis problem after rotary use
  1. #13
    Dec 2009
    Default Re: Chinese laser y-axis problem after rotary use
    New at laser engraving. I have the same problem after disconnecting the rotary attachment. My y axis dimensions are half the size. Sorry but I don't know what the CFG is and where to find it to download. Is there some kind of reset on the power supply? I've checked my leads and they seam to be okay. I'll check them again. If possible can you email me any help you can give @ - tunastap1@msn.com.
    Thank you for your time,
    Dbtuna
  2. #14
    Dec 2009
    Did you ever get your problem solved?
  3. #15
    Dec 2009
    YES! I figured it out myself. After attempting using the rotary attachment I disconnected it and reconnected the Y-axis plug. I didn't remember to UNCHECK the rotary box in the driver. All is well now.
    Even got the rotary attachment working I got on Amazon.
