Gweike laser cutter is biggest laser cutter manufacture in north of china.we make one new model LC1313,which can cut wood,acrylic,rubber etc,also the stainless steel,carbon steel,spec is as follows:
Model LC1313
Engraving size 1300*1300mm
Overall dimensions 2,100x2,000X1,200mm
Laser power V6(130w)
Cutting speed 0 – 50 mm/s
Reposition accuracy ±0.05mm
Working voltage AC110- 220V±10%,50-60Hz
Consuming power less than 1,000W
Working temperature 0 - 45°C
Working humidity 8 - 95%
Minimum letter size English :1 x 1mm Chinese:2 x 2mm
Supported file format BMP, HPGL, PLT, DST, DXP, and AI
Driving system Servo motors
Laser tube cooling type Water-cooling chiller LW16 or cooling machine and protection system
Other auxiliary equipment Exhaust-fans and air-exhaust pipe
Laser control software DSP control system
Compatible software CorelDraw AutoCAD Photoshop
Laser tube type: Sealed CO2 glass laser tube
also pls check the detailed picture of the machine in attachment
