- Tips for laser power supply & tube upgrading
To friends here who want to upgrade laser power supply and tubes after some time using:
Tip 1: As for the power, not the larger the better. Power larger than 100W can not engrave well.
If your work is only cutting, then it is helpful if you upgrade so that you can cut thicker material and have faster speed.
If your work is only engraving, the best power will still be around 60W.
The best point for both work at the same time will be 60W-80W/Reci W2.
Tip 2: The larger power supply can give power to smaller tube but not vice versa.
Some parameter for Chinese tubes :
Reci:
W2 90W, peak power 100W length: 1200mm diameter: 80mm
W4 120W, peak power 135W length: 1400mm diameter: 80mm
W6 150W, peak power 170W length: 1650mm diameter: 80mm
W8 170W, peak power 195W length: 1850mm diameter: 90mm
Other brand tubes:
80W length: 1600mm diameter: 80mm
60W length: 1200mm diameter: 55mm
40W length: 1000mm diameter: 50mm
30W length: 700mm diameter: 50mm
25W length: 600mm diameter: 50mm
Melody
li@wklaser.com
- You may not post replies
- You may not edit your posts
Forum Rules
