email me poulinphotography@gmail.com I will see if I can get you the language file.
I have a problem that my lasercut 5.3 software is half chineese and half englisch.
My supplier send me already the same file.
Maybe someone can send me this file. Or give a good sugestion how to get this.
Many thanks
- how to change my DSP language ?
- Language
- Need Help!- Language settings?
- Need Help!- Lasercut 5.1 language file
Hoi Harry,
I have the same problem, I need a better language.ini file for LaserCut 5.3.
My other issue is the config file for the laser itself, which seems to be wrong for my machine, but it is difficult to debug if you don't even have a correct language file, as the important things about my motion controller options are all not in english.
Did you get a correct language.ini file?
met vriendelijke groet, René
Check
CNC lasers, constructions, service
thank you, but unfortunately there is the same issue near the codes for the lasermode, search for string 459_0, 459_1, etc until 459_4, they read for example 459_0=Ä£ÄâÐź which seems chinese to me.
This one is from MPC6535.
