NestProfessor is a different software than lasercut. The way it works is, let's say you have 20 different pieces to cut, you load your design into NestProfessor, and it does what's called nesting, it will find the optimal layout to cut all your parts with the least amount of wasted material. Very good if you will be cutting lots of parts.
