So, where does one get the Lasercut 5.3 software? I have not found it anywhere. The Leetro site will not let you download it as a demo. I do not believe it can work with a moshi based machine. If I am wrong, I apologize. The Leetro site states that it is compatable with the MPC03 or MPC6515 controller card. Moshi uses a completely different controller card.
Milt
jenny@wklaser.com
skype:ms.leizhang www.wklaser.com
I'm not sure if you have already found a solution...
But I'm running a Chinese laser I bought for pretty cheap and find it pretty quick and easy to design something in corelDraw then just export it as a .dxf file, then import it into RDWorksV8 (Not a very good designing program, but you can get it free online, and it works for my laser just fine) Play around with the export settings until you get it right, but you should be able to just import a design, change the settings for the laser depending on how deep you want everything (can cut and engrave in the same job using multi-colors just like corelDraw) Then pressing start.
Hope this helps, I didn't go into very much detail in this, but if you would like I could do that because after a few months of playing with the settings, I have it to where I can run my cheapo laser as smoothly as I could with a $10,000+ machine I had at my school
Good luck
