Biesse Rover 346 retrofit - Page 4
Page 4 of 4 FirstFirst 1234
Results 37 to 38 of 38
Thread: Biesse Rover 346 retrofit
  1. #37
    Aug 2005
    Default Re: Biesse Rover 346 retrofit
    Quote Originally Posted by sting007 View Post
    I have same machine type and need to retrofit it but i do not have the wiring for it, could you provide it
    Sting
    I'll see what I can do. I will have to scan the manual.
    Where are you located BTW and what year is your machine? Does it have rs485 relay modules or not?
  2. #38
    May 2011
    I am using the spindle from a Biesse Rover on a DIY build.
    I'd also seriously appreciate any documentation, but in my case, specifically about the spindle wiring. I still haven't figured out what the pins are for and what the working pressures for the tool change, which port does what, etc.
    Biesse Rover 346 retrofit-01-spindle-jpg
    Biesse Rover 346 retrofit-03-six-pins-labelled-jpg
