Biesse Rover 346 retrofit - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 25 to 36 of 38
Thread: Biesse Rover 346 retrofit
  1. #25
    Aug 2005
    Default Re: Biesse Rover 346 retrofit
    Quote Originally Posted by bramvh View Post
    I am also going to use Linuxcnc with Mesa cards, on my machine the servo drives get feedback from the motors via hall effect, and the hohner encoder on the motors goes directly to the controller it doesn't go to the drive, there are 2 types of feedback from the servo motor one goes to the drive the other one goes to the controller, the controller sends an analog signal to the drive
    I allready did mine and all motor wiring goes to the drives. There is no encoders on mine going directly to the controller. From the Yaskawa drives, it went to the controller. I removed them and connected them to the 7i77. It is an output out of the yaskawa drives.
    Mine is using Yaskawa drives. It is a 1995. Maybe on yours it might be but I havent seen it. What year is yours?
    EDIT
    Sorry, mine is a Biesse 346, not the same machine....
    /EDIT
  2. #26
    Jul 2007
    Belgium
    Quote Originally Posted by bevins View Post
    I allready did mine and all motor wiring goes to the drives. There is no encoders going directly to the controller.
    the machine is from 1991, and uses GEC ALSTHOM drives from PARVEX type CMS2 attached is a photo, to my knowledge all 342 machines uses these types of drives, the 346 machines have other drives and motors
    Biesse Rover 346 retrofit-img_5778-jpg
  3. #27
    May 2007
    Austria
    My machine also hast GEC ALSTHOM PARVEX drives + motors, it seems the drives get feedback via separate resolver, and the NC controller gets position via Hohner optical incremental encoders. Didn't find anything about them either, nevertheless, it should work in principle, encoder has sticker with pinout / how the cable is used. I'm not sure what voltage they run on or what kind of signal they deliver.
    Inspecting the NC axis control board, i found some AM26LV32 chips, so it would not surprise me if encoder signaling was rs-422 levels, two phases with index (A+/-, B+/-, O+/-). Will check with oscilloscope before doing anything stupid.
    Encoder on 4th axis seems to be damaged. Zeroing C-Axis in original CNI controller spins forever...
    For interfacing the inputs and outputs (relay-boards) I designed some custom PCBs to connect the CNI breakout-boards to the mesa cards, PCBs should arrive in 2 weeks, will post update if and when it works out
  4. #28
    Jul 2007
    Belgium
    Seems like you have some advantage over me I do not have a working controller, nor do I have stickers on the encoders so I don't know what cable does what, but you are right, they do seem to be differential signal, I haven't worked out the voltage they run on either.
    Could you share some pictures or maybe do some measurement on the voltage going to the encoder?
    Maybe we should create a new topic for our conversion, but I don't know where to put that.
    Best regards,
    Bram
  5. #29
    May 2007
    Austria
    I have the schematics nearly completed, the NC and some E-Stop stuff are the last missing parts. Will put it on github or something when ready.
    Voltage- and other measurements are planned for next week, also have to figure out how to do a tool change with the CNI controller to take notes what has to be activated where and when...
  6. #30
    May 2007
    Austria
    Some pictures of the Y-axis encoder and where the cables are connected.
    Attached Thumbnails Attached Thumbnails Biesse Rover 346 retrofit-dsc_1201-jpg   Biesse Rover 346 retrofit-dsc_1203-jpg   Biesse Rover 346 retrofit-dsc_1214-jpg
  7. #31
    Jul 2007
    Belgium
    Thanks for that,
    unfortunately the color codes do not match real life for me, and the type of encoder is slightly different mine has no 0 at the end,
    the picture of the connections is for the Hall effect sensors they go to the drive, the encoder cables go directly to the NC
  8. #32
    May 2007
    Austria
    Thanks for that,
    yeah, thats possible. Did not trace the cables. The machine is very dusty, the cabinet needs another round of vacuuming.
    The habit of running cables through the cabinet to the NC and the drives is somewhat nasty. Makes it nearly impossible to disconnect the whole cabinet.
  9. #33
    May 2007
    Austria
    pinout of the CNI axis controller is:
    First axis encoder: 18Z, 18D: A', A; 16Z, 16D: B', B; 14Z, 14D: Z, Z', colors are green/orange, gray/yellow and white/red. second axis encoder is 12Z-8D, third axis 6Z-2D.
    Output to servo drives is on 32D/Z resp. 30D/Z resp. 38D/Z, supply for encoders is 20D, 22D (both +12V) and 20Z/22Z (GND).
    Pinout is written on male connector (the one on the card), first row up is 32, then 30 and so on, columns are Z (leftmost), B, D.
    Voltages on encoder lines is +12V/0V resp. inverse.
    Hope this helps.
  10. #34
    Jul 2007
    Belgium
    Thanks that is extremely helpful
    I received my mesa cards yesterday, I will probably be installing them this week, I am going for a 5i25 + 7i77 + 7i74 and on the 7i74: 7i70 + 2x7i71 + 7i73 + 7i83
    so from your post I understand that:
    A' = green
    A = orange
    B' = gray
    B = yellow
    Z' = white
    Z = red
    GND = black
    +12V = blue
    Attachment 358344
    Attachment 358346
  11. #35
    May 2007
    Austria
    from your post I understand that...
    This information is from the schematics. I checked only the A-channel of the Z-axis with the oscilloscope, but pinout, cable colors etc... is consistent with the other axis and makes sense.
    My setup will be one 7i90 with SPI, one 7i44 and one 7i48, and a bunch of 7i90s with smart serial for I/O. Controller will be a RaspberryPi 3 (most probably). Received the cards yesterday, currently fighting the firmware.
  12. #36
    Registered sting007's Avatar
    Feb 2015
    Hi all,
    I just purchased a Biesse Rover 346 with intents of retrofitting with Linuxcnc.
    I plan on using mesa cards:
    5i25, 7i77, 7i74, 7i70 and 2X 7i71.
    I have the machine in my shop and mapping out all the I/O's.
    Waiting on connectors to connect 600V to the machine.
    See some pics below:
    I have same machine type and need to retrofit it but i do not have the wiring for it, could you provide it
    Sting
