NC Studio Z axis wont work with PLT File
Results 1 to 2 of 2
Thread: NC Studio Z axis wont work with PLT File
    Jun 2012
    UK
    Question NC Studio Z axis wont work with PLT File
    Morning All,
    You will probley laugh at me as its probley an easy answer. :-)
    Ok I have a new CNC Machine running NC Studio.
    I can cut 2D all day long from PLT files but only using the Depth in the Perameters section.
    So if I want to do a multi cut:
    eg: Circle 100mm Dia 10mm high with 3 cuts 3.5mm deep how do you do that?
    The multipass info from Signlab exported with the info for PLT has the info inside the drawing, but when I goes to cut Z axis does not move. It will only work if I tell the depth in the PLT Import Perameters.
    I tried some 3D multipass and had the same problem the image is flat not 3D
    Spent 5 hours with the program and the manual but still failed.
    Let me know ;-)
    Have another question about the M Coordinate but will sort this problem first.
    Oct 2015
    Quote Originally Posted by Palmpro Stu View Post
    Morning All,
    Let me know ;-)
    I got the same problem if you find yet a solution conct me ivankaratanov@yahoo.com
