- 5axis machine is not operating on Constant given Feed while using A-axis and C-Axis
Hi all
I am using 5 Axis machine with heidenhain control. I am doing a 5 axis operation.
I input feed as 1000 mm/min but when A-axis and C-Axis moves while program run,machine autometically set feed below then 500mm/min which doesn't remain constant.
I don't why it does happen. I think while All axis are synchronised ,machine limitize the feedrate corresponding the limitions of A-Axis and C-Axis, I am not sure.
If some one knows please tell me how to overcome this problem. I want to keep constant my cutting feed while execution of M128( Axis Synchronisation) mode.
Hello guys its all about feedrate in TCPM OR M128 . Can any one please tell me the difference of both feedrates which uses in TCPM mode.
Re: 5axis machine is not operating on Constant given Feed while using A-axis and C-Ax
No product or service may be provided in the region
- You may not post replies
- You may not edit your posts
Forum Rules
