- Conversion
Conversion
Hi we have 4 XYZ machines and are excellent BUT we also have a pinnacle with a Acu-Right controller the question is can you convert this to a XYZ protrack controller this making all machines the same as Acu-right is murder to use plus it only has a floppy disk drive for inputing code from Alphacam
thanks
Re: Conversion
The short answer is YES. As long as the Pinnacle machine ''looks'' like the XYZ machine to the controller it should work fine. The difficulty might be in getting the Pinnacle machine to be compatible with the ProTrack controller. The most important issue would be the axis motor/drive compatibility. If they are controlled in the same way on both machines then it should be pretty easy.
Re: Conversion
thats Great thanks i will no doubt get someone in to give us a price to do the job. its a shame because everyone shys away from it.
- Conversion
- You may not post replies
- You may not edit your posts
Forum Rules
