Help needed to incorporate harmonic drives in a 4th and 5th axis head.
Results 1 to 2 of 2
Thread: Help needed to incorporate harmonic drives in a 4th and 5th axis head.
    Registered SpookyDad's Avatar
    Feb 2006
    Default Help needed to incorporate harmonic drives in a 4th and 5th axis head.
    I recently acquired two harmonic drives and wish to use them to build a 4th and 5th axis head. It will be similar to a doughty drive. The harmonic drives are only the large ring, the flexible cup and the wave generator. There is no housing so I will have to I corporate these in the head itself.
    I will be mating these to an 80mm water cooled spindle.
    Jul 2015
    Default Re: Help needed to incorporate harmonic drives in a 4th and 5th axis head.
    Hi, I'm currently building a very similar machine. Check out my thread of you want:
    http://www.cnczone.com/forums/cnc-wo...ml#post1906402
