Need Help! FANUC 16-W switch language
Results 1 to 3 of 3
Thread: FANUC 16-W switch language
    Sep 2017
    Lithuania
    Default FANUC 16-W switch language
    Hi, I have encountered such a problem, bought machines, and I do not know how to switch language, now it's French, but you need to be English, can you help me?
    The machine: FANUC robocut alpha-0B with Fanuc series 16-W
    P.S. Maybe I'll figure out how to solve this problem?
    Attached Thumbnails Attached Thumbnails FANUC 16-W switch language-21764141_1740192282666481_2068328950_o-jpg
    Aug 2017
    Default Re: FANUC 16-W switch language
    It is a parameter setting. I cannot tell you which setting number it is, however. You would need the FANUC manual for this control. If you have the manual, you just need to find the right parameter. From there, the book will tell you what you need to input to change to the desired language. If you do not have the manual, I would recommend contacting FANUC tech support.
    Nov 2017
    United Kingdom
    hi there, do you still have this problem?
