- Fanuc Wire EDM : is the feed override switch helpful.
I am looking for some experienced opinions about the
feed override switch on the control panel.
I sometimes use it after a wire break to insure the wire
gets going smoothly , then put it back to 100%
I have also used it at a minus setting through the entire roughing
cycle and prevented unwanted wire breaks, while still getting an accurate
cut and a good finish.
Although a correct A I conditions setting is always the correct way to go,
What are the pro`s and con`s of using the feed override switch.
Thanks, Tom
- You may not post replies
- You may not edit your posts
Forum Rules
