- Need Help!- Roboform 550 Slow Tank Fill
Good Morning Community!
I currently have a Roboform 550 that is slow filling and eventually throwing up Error E1009. I have check everything everything from the floats, seal, lines in the tank, to the pump itself. Everything seems to be in good working order. The pump is putting out 52 Gal/Min. The floats are working correctly. The die-electric fluid is in between the min/max level. The electrical current is what it should be. I am kind of scratching my head as to where to go from here. Any help on this matter would be greatly appreciated!!
Re: Roboform 550 Slow Tank Fill
Make sure that the machine is working with the correct air pressure (i think its ~2bar but check the marker next to the guage) or it will not properly seal and you will have more fluid returning to the reservoir than entering.
- You may not post replies
- You may not edit your posts
Forum Rules
