Hi
Anybody know how change language in my robocut?
Machine is from Germany, I need English version for use.
I found solution:
press SET
enter 9991
PAGE UP
screen "Handy parameter setting"
cursor position 12
soft key English
power off/on
This is not clear 16 system, but thanks Mike.
Hi can you help I’m running a fanuc alpha oc with 16w control, I’ve got the parameter page up using 9999 and page up, I’ve cursored down to the value I want to changed but can’t change the value by pressing input, what procedure do I use to change the value many thanks in advance
