- Wiring Confusion Mitsubishi DWC 90 SB Wire EDM
Hi, hope someone can help me out, seems Mitsubishi won't without joining their club. I have three sets of manuals for this machine but none show or tell about wiring it up. Manuals are SB Parts Manual, & B Series Wire Cut Systems. I have about 8 wires that come from the back behind the wire spool and enter the left side of the control cabinet when facing the CRT Display. Some of the wires are labeled but do not match any terminals listed.
Coming from the machine are:
Bundle #1( W1C, E1C) &Bundle #2 (W2C, E2C)
Bundles 1A &2A (Black Wire ), 1B & 2B ( White Wire)
Right and Left Terminal Bars have 4 connectors each: YCC - WO - W - E
Terminal Bar on the bottom is Listed as:
W2 - E2 - W1 - E1 - WE - P - O
Any help would be greatly appreciated
Thanks.
Bob
Re: Wiring Confusion Mitsubishi DWC 90 SB Wire EDM
Hi did you resolve the problem. Because I have the same problem with my machine , and I would like to know if you can help me with some pictures about this.
The pictures 1303 and 1304 Those are on the top of the tank, and the the pictures 1306 and 1308 leave the back of where the wire is rolled, see picture 1307.
good day
That problem is not well stated I recommend you openly say the problem to be able to support you to solve it friend.
I have a source problem with that same machine only that I have not found how to turn on the sources I turn on the machine and the power on process but at the moment of turning the ready does not turn on the sources, if someone has been through some problem so I could support .
Hi, I need help I just bought a wire edm Mitsubishi DWC90-SB, it is already connected but it gives me an alarm 729: ERR. USED-WIRE COLLECTION BOX PUMP.
I also need help in filling the tank, and also how to do a setup.
Thank you
- You may not post replies
- You may not edit your posts
Forum Rules
