Need Help! sodick A320D EX21 control
Results 1 to 5 of 5
Thread: sodick A320D EX21 control
    Feb 2007
    australia
    Wink sodick A320D EX21 control
    Hi all,
    I am having trouble with my Sodick A320D with EX21 control. On firing up the machine I get an error flashing "H004 DATA FILE IS NOT FOUND IN DRIVE 2, SET THE DISK AND PUSH ENT".
    I reset the disk and remove and insert the floppy in drive 2 and still get the same error. I have inserted a new user disk and still the same error. Can I bypass this error and proceed to fire up machine? has anyone out there seen this before and have a remedy? My sodick service rep is overseas for 2 weeks and I need to get my machine going desperately.
    Any help would be appreciated.
    Thank you.
    Jul 2014
    Default Re: sodick A320D EX21 control
    We actually had that problem on our Sodick A320L with the Mark EX control. We had to send the computer in for repair. Something about a blown capacitor I believe.
    Mar 2016
    Morocco
    please can you help me,
    i have a problem on my sodick A320D ex21,
    when it is loading it stops on (system loading 12/100) and show red message:
    (SYS2 version up install
    Insert the floppy disk in the USER side ,press the any kay.)
    can you help me pls?
    i need floppy disk 1 and 2 and 3
    May 2017
    Mexico
    Does anyone solved the problem on SYS2 VERSION INSTALL DISK?
    Quote Originally Posted by cncmedcom View Post
    Hi all,
    Thank you.
    Did you end up fixing this problem ?
    Apreciate any help
    thanks
    Member Joseph14's Avatar
    Feb 2022
    Hi how do you reset the disk? i have only on floppy driver, thanks in advance
