Charmilles Robofil 200 startup - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 47 of 47
Thread: Charmilles Robofil 200 startup
  1. #41
    May 2017
    Bosnia And Herzegovina
    Default Re: Charmilles Robofil 200 startup
    Hello to everyone, I have a problem with my Charmilles Robofil 2000, when I turn it on I get massage "Going to sleep mode".
    Anyone Help?
  2. #42
    May 2017
    Anyone Help?
  3. #43
    Member jdamaral's Avatar
    Sep 2019
    Default Re: NO AXIS Reference
    Hi I'm new on the forum but I see a lot of people that need to make boot disks for this old charmilles machines! So this image attatched is a formated in machine blank one, just use winimage, and REMEMBER first file added on the image NEEDS TO BE THE BOOT FILE (.BX8) than add other files!
    Cheers!
    PS: This image can be used with usb emulator for boot disk! just add the BX8 file first in the image save and than add the rest! (I use it with a GOTEK SFRM72-FU)
    Attached Files Attached Files
  4. #44
    Member nour4151's Avatar
    Jul 2021
    hello bigodino,
    I have a charmilles robofil 400. I have the same problem with booting. When I insert the communication floppy and press charger the same error occurs
    “ chargement#cks erreur format
    Did you solve the problem?
    thank you in advance for reply
  5. #45
    Jul 2021
    Hello jdamaral,
    i coudn't find the attached image
    Could you please send me by email the BX8 file
    email: nour4151@gmail.com
  6. #46
    Member Edmrepair's Avatar
    Aug 2021
    Are you still having trouble the machine software is not a big problem here.
    Greatlakeswirerepair@gmail.com
    Sent from my SM-G975U using Tapatalk
  7. #47
    Member manurdo's Avatar
    Sep 2022
    Can anyone please tell me what is the firmware and how can i purchase for the charmilles roboform 20 annee 1996. Because the machine issue when loading communication disk and press chagement to charger after the loading it view on the screen EFF PA3? . Can anyone tell me what is this for? in my openion some sector or file was corrupted in the os or firmware installed in the chips or eeprom for that model at the bottom of the circuit board behind the floppy drive or KB of machine cover. Kindly please help me i am willing to purchase this software or firmware if advice and available. pls you can email me ineed asap..
    my email : barberopinoy@gmail.com
    Thank you
    man
