General EDM Discussion
Page 1 of 19 123411 ... LastLast
Threads 1 to 20 of 375
Forum: General EDM Discussion
Discuss building, operating EDM machines here!
  1. Need Help!- FANUC 16-W switch language
    Started by TonizzZ‎, 09-14-2017 12:17 PM
    09-15-2017, 11:35 AM Go to last post
  2. Need Help!- Charmiles robofill 440 ''Gotek'' usb floppy emulator problem!!!
    Started by xal3r‎, 09-04-2017 01:58 PM
    09-04-2017, 01:58 PM Go to last post
    08-30-2017, 01:24 PM Go to last post
  3. roboform c axis
    Started by rwkjr‎, 01-25-2013 05:17 PM
    its, then
    08-18-2017, 02:25 PM Go to last post
  4. Post Charmilles 440 Wire Reel Motor Issue
    Started by Kmjgarvey‎, 08-09-2017 12:19 AM
    charmilles, issue, motor, rheostat, working
    08-16-2017, 02:55 PM Go to last post
  5. Question Charmilles Robofil Wire Edm
    Started by sundara‎, 11-23-2003 07:19 PM
    2 Pages
    1 2
    #22, 122, 222, absolute, charmilles, control, edm, experience, machine, machines, machining, manual, mdi, model, mor, move, not, power, power supply, robofil, running, simple, star, starts, supply, type, wire, wire edm, works
    08-01-2017, 04:56 PM Go to last post
  6. Problem- Charmiles robofil 440 Graphic problem !!
    Started by xal3r‎, 07-28-2017 06:55 AM
    g41, x-18.4142, x-7.5, x27.5, y-.588
    07-28-2017, 06:55 AM Go to last post
  7. Problem- Charmiles robofil 440 Zero point problem!!
    Started by xal3r‎, 07-26-2017 01:06 AM
    g40, x-18.4142, x-7.5, x27.5, y-.588
    07-26-2017, 01:06 AM Go to last post
  8. Newbie- Sure First ZPNC-408
    Started by Sensei1953‎, 07-25-2017 10:24 PM
    cnc, machine manual, manual, zpnc-408
    07-25-2017, 10:24 PM Go to last post
  9. Need Help!- Charmiles robofil 440 sl finding corner and language
    Started by xal3r‎, 07-22-2017 05:30 PM
    finding, language, machine, main, robofil
    07-22-2017, 05:30 PM Go to last post
  10. Need Help!- Brother HS-350 Fiber Error
    Started by BetaBob‎, 07-18-2017 10:18 AM
    board, brother, edm, error, hs350
    07-18-2017, 10:18 AM Go to last post
  11. Need Help!- Mitshubishi DWC-90SB
    Started by mihaisilcom‎, 07-17-2017 07:39 AM
    correct, dwc-90sb, resistance, small, wire
    07-17-2017, 07:39 AM Go to last post
  12. Cutting speed of MV1200S mitsubishi EDM?
    Started by Green0‎, 06-19-2017 02:32 PM
    cutting speed, edm, feed, mitsubishi, mv1200s
    06-28-2017, 05:57 PM Go to last post
  13. Technology parameters explanation Agie Charmilles
    Started by LEGIA‎, 06-17-2017 02:51 PM
    inj, parameter, parameters, polarization, units
    06-17-2017, 02:51 PM Go to last post
  14. Need Help!- I need, Software for machine AGIE 150 hss
    Started by joanlaga‎, 02-23-2016 07:07 AM
    agie, agie 150, hss, machine, software
    06-15-2017, 04:59 PM Go to last post
  15. Accutex EDM
    Started by marsh12718‎, 12-14-2012 01:15 PM
    mos
    06-12-2017, 05:34 AM Go to last post
  16. Need Help!- AGIE MFL
    Started by Zakhar_76‎, 06-06-2017 04:48 AM
    06-11-2017, 01:10 AM Go to last post
  17. Wink Need Help!- sodick A320D EX21 control
    Started by cncmedcom‎, 05-27-2014 12:03 AM
    05-30-2017, 10:50 PM Go to last post
  18. Newbie- Disk EDM SODICK marx X
    Started by soleh‎, 05-29-2017 02:55 AM
    05-29-2017, 02:55 AM Go to last post
  19. Charmilles Robofil 200 startup
    Started by Shawn Lucas‎, 05-12-2010 06:17 PM
    4 Pages
    1 2 3 4
    05-16-2017, 12:40 PM Go to last post
Forum Information and Options
Moderators of this Forum
Users Browsing this Forum
There are currently 10 users browsing this forum. (0 members & 10 guests)
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 25 replies or 500 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
