Make sure your lead in / lead out lengths and type are set correctly in sheetcam. They are set when you select the operation. Also, make sure that you have the room for these when you compile your drawing in sheetcam. If you don't have room where sheetcam puts the start point, you can edit the location of that particular start.
Good luck,
Willy
