Can someone tell me an idea of what is wrong with my THC?
When starting to run a program, the control performs a Position test, so the torch is approached to the sheetmetal but then keeps going up and down indefinitely. please see short video of movement.
Is it the THC itself, or maybe the THC is not relaying the output signal from the limit switches to the control?
Any thoughts would be much appreciated. Thank you!.
Do you use a floating head or Ohmic sensing? How do you reference the torch-to-plate? If floating head, could be a connection issue.
Does it have the same problem when the THC is not active?
