Plasma table recommendation
Results 1 to 2 of 2
Thread: Plasma table recommendation
    Jul 2017
    United Arab Emirates
    Default Plasma table recommendation
    Hi all
    I'm a newbie, I'm a mechanical automotive engineer,
    I wanna start a business for sheet metal art and automotive fabrication, I'm located in Dubai
    A CNC plasma cutter will be the core equiment for that
    Will be cutting mild steel mostly, occasionally Aluminum and stainless steel
    Thickness mostly 2mm to 5mm with very few 3/8" or 1/2"
    Will be using 4x8' sheets, but might consider upgrading to 5x10' if price difference is not that big,
    I'm expecting to cut a dozen sheets or so daily, I need something that is precise, reliable and
    It seems that everybody agrees on the Powermax, I wish it was the same for the plasma table
    Some were recommending Arclight, but others were against the non-welded frame
    Also many opinions are in reply of several years old inquiries where apparently Arclight were using the Mach software and now I believe they moved to Linux, I'm not sure which will be more suitable for my application
    Other names include LDR, torchmate, JD squared…. I feel lost
    As for the budget, I'm trying to be a little flexible but preferably no more than the 30k budget
    Thanks in advance for any recommendations and adviseHi
    I'm a newbie
    Will be cutting mild steel mostly, some Aluminum and stainless steel
    I'm expecting to cut a dozen sheets or so daily, I need something that is precise, reliable and easy to use
    Also many opinions are in reply of several years old inquiries where apparently Arclight used to use the Mach software and now I believe they moved to Linux, I'm not sure which will be more suitable for my application
    Inspiro
    Jul 2017
    Default Re: Plasma table recommendation
    At Hornet Cutting Systems, we offer a wide range of CNC cutting tables. With different sizes, styles, and specifications, we have the ideal equipment to meet your needs. To check out our CNC cutting tables, visit our website at https://hornetcs.com/cnc-cutting-tables/.
    If you have any further questions, please contact us at 1-844-209-5552. We'd be happy to help find the right equipment for you.
